robfantini's avatar
robfantini
3 port lag question.
We have 3 of those swit hes in a stack.
I have a lag set up using 1/0/11, 2/0/11, 3/0/11
at switching >  lag configuration 2 ports are active and lag state is UP
the target switch is a M4100-50G-POE+ .    hash type for lag = 6 .
the lag works for ports 1/0/11 and 2/0/11  .
when I move one of the patch cables to  3/0/11  , the port does not lite up.
here is more info:
interface 1/0/11
addport lag 11
exit
interface 2/0/11
addport lag 11
exit
interface 3/0/11
addport lag 11
exit
interface lag 11
auto-voip protocol-based
port-channel load-balance 6
dhcp l2relay
mtu 9216
vlan pvid 8
Should we be able to use 3 ports on a lag?
And if so any hints on what to check for?
regards
Roberto
  • Retired_Member's avatar
    Retired_Member
    Jul 13, 2017
    robfantini
    Ok, I known your concern.
    Could you please change port-channel load-balance to default 3, and try again?
  • here is more info:
    at System>Stacking>Stack Configuration the 3RD switch has 'Standby Status'  as 'Opr Standby' .
    the other two switches Standby Status = none .
    I wonder if that is causing an the issue with 3RD port not working?
      Retired_Member
      Hi robfantini,
      Welcome to the community!
      Could you please execute CLI command as below, we need get more detailed information:
      1. show port-channel 11
      2. show port 1/0/11; show port 2/0/11; show port 3/0/11;
      3. show running-config interface lag 11
      4. show version
      EricZ
      NETGEAR employee
      • robfantini's avatar
        robfantini
        here is the info:
        (GSM7352Sv2) #show port-channel 11
        Local Interface................................ lag 11
        Channel Name................................... ch11
        Link State..................................... Up
        Admin Mode..................................... Enabled
        Type........................................... Dynamic
        Port-channel Min-links......................... 1
        Load Balance Option............................ 6
        (Src/Dest IP and TCP/UDP Port fields)
        Local Preference Mode.......................... Disabled
        Mbr    Device/       Port      Port
        Ports  Timeout       Speed     Active
        1/0/11 actor/long    Auto      True
               partner/long
        2/0/11 actor/long    Auto      True
               partner/long
        3/0/11 actor/long    Auto      False
               partner/long
        (GSM7352Sv2) #show port 1/0/11
                          Admin   Physical   Physical   Link   Link    LACP    Flow
         Intf      Type   Mode     Mode       Status     Status Trap    Mode    Mode
        1/0/11    PC Mbr Enable    Auto       1000 Full  Up     Enable  Enable Enable
        (GSM7352Sv2) #show port 2/0/11
        2/0/11    PC Mbr Enable    Auto       1000 Full  Up     Enable  Enable Enable
        (GSM7352Sv2) #show port 3/0/11
        3/0/11    PC Mbr Enable    Auto                  Detach Enable  Enable Disable
        (GSM7352Sv2) #show running-config interface lag 11
        !Current Configuration:
        interface lag 11
        dhcp l2relay
        mtu 9216
        vlan pvid 8
        vlan participation auto 1
        vlan participation include 8,37,41-42,60,65,199-201
        vlan tagging 37,41-42,60,65,199-201
        exit
        (GSM7352Sv2) #show version
        Switch: 1
        System Description............................. GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.33
        Machine Model.................................. GSM7352Sv2
        Serial Number.................................. 24P6285C00006
        Burned In MAC Address.......................... 4C:60:DE:E4:C4:D3
        Software Version............................... 10.0.0.53
        Bootcode Version............................... 01.00.33
        Supported Java Plugin Version.................. 1.6
        Current Time................................... JUL 06 09:52:48 2017 (UTC-5:00)
        Current SNTP Sync Status....................... Success
ProSupport for Business
