robfantini
Jul 05, 2017Aspirant
3 port lag question.
We have 3 of those swit hes in a stack. I have a lag set up using 1/0/11, 2/0/11, 3/0/11 at switching > lag configuration 2 ports are active and lag state is UP the target switch is a M4...
- Retired_MemberJul 13, 2017
Ok, I known your concern.
Could you please change port-channel load-balance to default 3, and try again?
robfantini
Jul 13, 2017Aspirant
please re check what I wrote: for 1ST test:
"ping from switch works
** ping from host does not.** "
Retired_Member
Jul 13, 2017
