robfantini
Jul 05, 2017Aspirant
3 port lag question.
We have 3 of those swit hes in a stack. I have a lag set up using 1/0/11, 2/0/11, 3/0/11 at switching > lag configuration 2 ports are active and lag state is UP the target switch is a M4...
- Retired_MemberJul 13, 2017
Ok, I known your concern.
Could you please change port-channel load-balance to default 3, and try again?
robfantini
here is more info:
at System>Stacking>Stack Configuration the 3RD switch has 'Standby Status' as 'Opr Standby' .
the other two switches Standby Status = none .
I wonder if that is causing an the issue with 3RD port not working?
- Retired_MemberJul 05, 2017
Hi robfantini,
Welcome to the community!
Could you please execute CLI command as below, we need get more detailed information:1. show port-channel 11
2. show port 1/0/11; show port 2/0/11; show port 3/0/11;
3. show running-config interface lag 11
4. show version
EricZ
NETGEAR employee- robfantiniJul 06, 2017Aspirant
here is the info:
(GSM7352Sv2) #show port-channel 11 Local Interface................................ lag 11 Channel Name................................... ch11 Link State..................................... Up Admin Mode..................................... Enabled Type........................................... Dynamic Port-channel Min-links......................... 1 Load Balance Option............................ 6 (Src/Dest IP and TCP/UDP Port fields) Local Preference Mode.......................... Disabled Mbr Device/ Port Port Ports Timeout Speed Active ------ ------------- --------- ------- 1/0/11 actor/long Auto True partner/long 2/0/11 actor/long Auto True partner/long 3/0/11 actor/long Auto False partner/long(GSM7352Sv2) #show port 1/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 1/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable (GSM7352Sv2) #show port 2/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 2/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable (GSM7352Sv2) #show port 3/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 3/0/11 PC Mbr Enable Auto Detach Enable Enable Disable(GSM7352Sv2) #show running-config interface lag 11 !Current Configuration: ! interface lag 11 auto-voip protocol-based port-channel load-balance 6 dhcp l2relay mtu 9216 vlan pvid 8 vlan participation auto 1 vlan participation include 8,37,41-42,60,65,199-201 vlan tagging 37,41-42,60,65,199-201 exit
(GSM7352Sv2) #show version Switch: 1 System Description............................. GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.33 Machine Model.................................. GSM7352Sv2 Serial Number.................................. 24P6285C00006 Burned In MAC Address.......................... 4C:60:DE:E4:C4:D3 Software Version............................... 10.0.0.53 Bootcode Version............................... 01.00.33 Supported Java Plugin Version.................. 1.6 Current Time................................... JUL 06 09:52:48 2017 (UTC-5:00) Current SNTP Sync Status....................... Success
- Retired_MemberJul 06, 2017
Hi robfantini,
As we see the port 3/0/11 status is 'Detach', I think maybe the unit 3 can't working normaly, right?
So please execute CLI command as below:
1. show switch
2. show stack-port
3. show port all
