robfantini
Jul 05, 2017Aspirant
3 port lag question.
We have 3 of those swit hes in a stack. I have a lag set up using 1/0/11, 2/0/11, 3/0/11 at switching > lag configuration 2 ports are active and lag state is UP the target switch is a M4...
- Retired_MemberJul 13, 2017
Ok, I known your concern.
Could you please change port-channel load-balance to default 3, and try again?
robfantini
here is more info:
at System>Stacking>Stack Configuration the 3RD switch has 'Standby Status' as 'Opr Standby' .
the other two switches Standby Status = none .
I wonder if that is causing an the issue with 3RD port not working?
Retired_Member
Jul 05, 2017Hi robfantini,
Welcome to the community!
Could you please execute CLI command as below, we need get more detailed information:
1. show port-channel 11
2. show port 1/0/11; show port 2/0/11; show port 3/0/11;
3. show running-config interface lag 11
4. show version
EricZ
NETGEAR employee
- robfantiniJul 06, 2017Aspirant
here is the info:
(GSM7352Sv2) #show port-channel 11 Local Interface................................ lag 11 Channel Name................................... ch11 Link State..................................... Up Admin Mode..................................... Enabled Type........................................... Dynamic Port-channel Min-links......................... 1 Load Balance Option............................ 6 (Src/Dest IP and TCP/UDP Port fields) Local Preference Mode.......................... Disabled Mbr Device/ Port Port Ports Timeout Speed Active ------ ------------- --------- ------- 1/0/11 actor/long Auto True partner/long 2/0/11 actor/long Auto True partner/long 3/0/11 actor/long Auto False partner/long(GSM7352Sv2) #show port 1/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 1/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable (GSM7352Sv2) #show port 2/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 2/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable (GSM7352Sv2) #show port 3/0/11 Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 3/0/11 PC Mbr Enable Auto Detach Enable Enable Disable(GSM7352Sv2) #show running-config interface lag 11 !Current Configuration: ! interface lag 11 auto-voip protocol-based port-channel load-balance 6 dhcp l2relay mtu 9216 vlan pvid 8 vlan participation auto 1 vlan participation include 8,37,41-42,60,65,199-201 vlan tagging 37,41-42,60,65,199-201 exit
(GSM7352Sv2) #show version Switch: 1 System Description............................. GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.33 Machine Model.................................. GSM7352Sv2 Serial Number.................................. 24P6285C00006 Burned In MAC Address.......................... 4C:60:DE:E4:C4:D3 Software Version............................... 10.0.0.53 Bootcode Version............................... 01.00.33 Supported Java Plugin Version.................. 1.6 Current Time................................... JUL 06 09:52:48 2017 (UTC-5:00) Current SNTP Sync Status....................... Success
- Retired_MemberJul 06, 2017
Hi robfantini,
As we see the port 3/0/11 status is 'Detach', I think maybe the unit 3 can't working normaly, right?
So please execute CLI command as below:
1. show switch
2. show stack-port
3. show port all
- robfantiniJul 07, 2017Aspirant
I got 'Message cannot exceed 20,000 characters' so for last command i removed a lot of what I whink were unnecessary lines.
#show switch Management Standby Preconfig Plugged-in Switch Code SW Switch Status Model ID Model ID Status Version --- ---------- --------- ---------------- ---------------- ------------- ----------- 1 Mgmt Sw GSM7352Sv2 GSM7352Sv2 OK 10.0.0.53 2 Stack Mbr GSM7352Sv2 GSM7352Sv2 OK 10.0.0.53 3 Stack Mbr Oper Stby GSM7352Sv2 GSM7352Sv2 OK 10.0.0.53
#show stack-port
Configured Running Stack Stack Link Link Unit Interface Type Product Name Mode Mode Status Speed (Gb/s) ---- ---------------- ------- ----------------- ---------- ---------- ---------- ------------ 1 0/49 Ethernet Ethernet Link Down 10 1 0/50 Ethernet Ethernet Link Down 10 1 0/51 AX742 (stack) Stack Stack Link Up 12 1 0/52 AX744 (cx4) Stack Stack Link Up 12 2 0/49 Ethernet Ethernet Link Down 10 2 0/50 Ethernet Ethernet Link Down 10 2 0/51 AX742 (stack) Stack Stack Link Up 12 2 0/52 AX744 (cx4) Stack Stack Link Up 12 3 0/49 None None Ethernet Ethernet Link Down 10 3 0/50 None None Ethernet Ethernet Link Down 10 3 0/51 None None Stack Stack Link Up 12 3 0/52 None None Stack Stack Link Up 12#show port all Admin Physical Physical Link Link LACP Flow Intf Type Mode Mode Status Status Trap Mode Mode --------- ------ --------- ---------- ---------- ------ ------- ------ ------- 1/0/1 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/2 PC Mbr Enable Auto Down Enable Enable Enable .. 1/0/7 PC Mbr Enable Auto Down Enable Enable Enable 1/0/8 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/9 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/10 PC Mbr Enable Auto Down Enable Enable Enable 1/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/12 PC Mbr Enable Auto Down Enable Enable Enable .. 1/0/17 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable .. 1/0/23 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/24 PC Mbr Enable Auto Down Enable Enable Enable 1/0/25 PC Mbr Enable Auto Down Enable Enable Enable .. 1/0/29 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/30 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/31 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/32 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/33 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 1/0/34 PC Mbr Enable Auto Down Enable Enable Enable .. 1/0/48 Enable Auto Down Enable Enable Enable 1/0/49 Enable 10G Full Down Enable Enable Enable 1/0/50 Enable 10G Full Down Enable Enable Enable 1/0/51 Enable Detach Enable Enable Enable 1/0/52 Enable Detach Enable Enable Enable 2/0/1 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/2 PC Mbr Enable Auto Down Enable Enable Enable .. 2/0/8 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/9 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/10 PC Mbr Enable Auto Down Enable Enable Enable 2/0/11 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/12 PC Mbr Enable Auto Down Enable Enable Enable 2/0/13 PC Mbr Enable Auto Down Enable Enable Enable 2/0/14 PC Mbr Enable Auto Down Enable Enable Enable 2/0/15 PC Mbr Enable Auto Down Enable Enable Enable 2/0/16 PC Mbr Enable Auto Down Enable Enable Enable 2/0/17 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/18 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/19 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/20 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/21 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/22 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/23 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/24 PC Mbr Enable Auto Down Enable Enable Enable 2/0/25 PC Mbr Enable Auto Down Enable Enable Enable 2/0/26 PC Mbr Enable Auto Down Enable Enable Enable 2/0/27 PC Mbr Enable Auto Down Enable Enable Enable 2/0/28 PC Mbr Enable Auto Down Enable Enable Enable 2/0/29 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/30 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/31 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/32 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/33 PC Mbr Enable Auto 1000 Full Up Enable Enable Enable 2/0/34 PC Mbr Enable Auto Down Enable Enable Enable .. 2/0/44 Enable Auto Down Enable Enable Enable 2/0/45 Enable Auto 1000 Full Up Enable Enable Enable 2/0/46 Enable Auto Down Enable Enable Enable 2/0/47 Enable Auto Down Enable Enable Enable 2/0/48 Enable Auto Down Enable Enable Enable 2/0/49 Enable 10G Full Down Enable Enable Enable 2/0/50 Enable 10G Full Down Enable Enable Enable 2/0/51 Enable Detach Enable Enable Enable 2/0/52 Enable Detach Enable Enable Enable 3/0/1 PC Mbr Enable Auto Detach Enable Enable Disable 3/0/2 Enable Auto Detach Enable Enable Disable 3/0/3 Enable Auto Detach Enable Enable Disable 3/0/4 Enable Auto Detach Enable Enable Disable 3/0/5 Enable Auto Detach Enable Enable Disable 3/0/6 Enable Auto Detach Enable Enable Disable 3/0/7 Enable Auto Detach Enable Enable Disable 3/0/8 Enable Auto Detach Enable Enable Disable 3/0/9 Enable Auto Detach Enable Enable Disable 3/0/10 Enable Auto Detach Enable Enable Disable 3/0/11 PC Mbr Enable Auto Detach Enable Enable Disable 3/0/12 Enable Auto Detach Enable Enable Disable .. 3/0/39 Enable Auto Detach Enable Enable Disable 3/0/40 PC Mbr Enable Auto Detach Enable Enable Disable 3/0/41 Enable Auto Detach Enable Enable Disable 3/0/42 Enable Auto Detach Enable Enable Disable 3/0/43 Enable Auto Detach Enable Enable Disable 3/0/44 Enable Auto Detach Enable Enable Disable 3/0/45 Enable Auto Detach Enable Enable Disable 3/0/46 Enable Auto Detach Enable Enable Disable 3/0/47 Enable Auto Detach Enable Enable Disable 3/0/48 Enable Auto Detach Enable Enable Disable 3/0/49 Enable Detach Enable Enable Disable 3/0/50 Enable Detach Enable Enable Disable 3/0/51 Enable Detach Enable Enable Disable 3/0/52 Enable Detach Enable Enable Disable lag 1 Enable Up Disable N/A Disable lag 2 Enable Down Disable N/A Disable lag 3 Enable Down Disable N/A Disable lag 4 Enable Down Disable N/A Disable lag 5 Enable Down Disable N/A Disable lag 6 Enable Down Disable N/A Disable lag 7 Enable Down Disable N/A Disable lag 8 Enable Up Disable N/A Disable lag 9 Enable Up Disable N/A Disable lag 10 Enable Down Disable N/A Disable lag 11 Enable Up Disable N/A Disable lag 12 Enable Down Disable N/A Disable lag 13 Enable Down Disable N/A Disable lag 14 Enable Down Disable N/A Disable lag 15 Enable Down Disable N/A Disable lag 16 Enable Down Disable N/A Disable lag 17 Enable Up Disable N/A Disable lag 18 Enable Up Disable N/A Disable lag 19 Enable Up Disable N/A Disable lag 20 Enable Up Disable N/A Disable lag 21 Enable Up Disable N/A Disable lag 22 Enable Up Disable N/A Disable lag 23 Enable Up Disable N/A Disable lag 24 Enable Down Disable N/A Disable lag 25 Enable Down Disable N/A Disable lag 26 Enable Down Disable N/A Disable lag 27 Enable Down Disable N/A Disable lag 28 Enable Down Disable N/A Disable lag 29 Enable Up Disable N/A Disable lag 30 Enable Up Disable N/A Disable lag 31 Enable Up Disable N/A Disable lag 32 Enable Up Disable N/A Disable lag 33 Enable Up Disable N/A Disable lag 34 Enable Down Disable N/A Disable .. lag 64 Enable Down Disable N/A Disable vlan 8 Enable 10 Half 10 Half Up Enable N/A Disable vlan 200 Enable 10 Half 10 Half Up Enable N/A Disable vlan 2 Enable 10 Half 10 Half Up Enable N/A Disable vlan 15 Enable 10 Half 10 Half Up Enable N/A Disable vlan 60 Enable 10 Half 10 Half Up Enable N/A Disable vlan 20 Enable 10 Half 10 Half Up Enable N/A Disable vlan 37 Enable 10 Half 10 Half Up Enable N/A Disable vlan 42 Enable 10 Half 10 Half Up Enable N/A Disable vlan 201 Enable 10 Half 10 Half Up Enable N/A Disable vlan 199 Enable 10 Half 10 Half Up Enable N/A Disable vlan 10 Enable 10 Half 10 Half Up Enable N/A Disable vlan 3 Enable 10 Half 10 Half Up Enable N/A Disable vlan 7 Enable 10 Half 10 Half Up Enable N/A Disable vlan 25 Enable 10 Half 10 Half Up Enable N/A Disable vlan 35 Enable 10 Half Down Enable N/A Disable vlan 40 Enable 10 Half 10 Half Up Enable N/A Disable vlan 41 Enable 10 Half 10 Half Up Enable N/A Disable vlan 65 Enable 10 Half 10 Half Up Enable N/A Disable vlan 70 Enable 10 Half 10 Half Up Enable N/A Disable vlan 80 Enable 10 Half 10 Half Up Enable N/A Disable vlan 90 Enable 10 Half 10 Half Up Enable N/A Disable
