Tcantech
Mar 24, 2021Aspirant
Link up but no MAC
A couple ports show as Up but no MAC to go with it. Port Configuration shows them as Link Up and the Port Statistics shows packets transmitted without error, more with each refresh so a live conne...
Tcantech
Mar 26, 2021Aspirant
Of course the address table is where I was seeing that there was no MAC for these Link Up ports. I have about a dozen ports showing Link Up. Most of those show up in the MAC address table. Some show up a couple of times if they go to multiple devices. But a couple of the ports showing as Link Up don't show in the address table at all. Yes, I've set it to Show All. One port has only ever had traffic as Packets Transmitted (in Port Statistics) but the other has had both Packets Transmitted and Packets Received (all without errors). How can that possibly be if the switch doesn't know the MAC? Is this an error of the display of the address table? Or something else?
JohnC_V
Apr 01, 2021NETGEAR Employee Retired
May I know what firmware version are you running on your switch? We may need to check if this is some kind of a bug on your firmware.
John
NETGEAR Community Team
- TcantechApr 01, 2021Aspirant
It's 1.0.0.34. The latest. Just updated it very recently when we got it.
