tantony
Jun 05, 2019Luminary
LLDP for VoIP phones help
I have a variety of Netgear smart switches in my network such as GS748TS, GS724TP and GS324T, but all of them are capable of LLDP and auto VoIP. I could use some help with configuring these smart switches for VoIP phones. Do I just create a voice VLAN, then assign that VLAN for voip? This is my first time configuring switches for VoIP. I'm assuming I need to configure VoIP on all the switches the phones will be connected to, correct? Is there any documentation?
A little bot older, but this should help: Configuring voice VLAN feature on the NETGEAR Smart switches
- tantonyLuminary
I created VLAN 5 as the voice VLAN. I enabled auto voip and assigned it VLAN 5. It looks like I have to enable LLDP on GS748TS, but the other switches, looks like LLDP is automatically turned on.
- tantonyLuminary
