tonynsx's avatar
tonynsx
Luminary
Apr 10, 2019
LLDP capable switches
I'm looking for LLDP capable switches for our VoIP phones.  Any recommendations?  They don't have to be PoE switches.
  • Hi tonynsx,
    I recommend you either the GC728X or GC728XP switches.  Both GC728X and GC728XP switches have 24 RJ-45 ports, 2 dedicated 1G SFP Fiber ports and 2 dedicated 10G SFP+ Fiber ports.  Also, both GC728X and GC728XP switches supports LLDP.  The main difference is that the GC728XP switch supports PoE/PoE+ while the GC728X does not.
    For more information about the specifications of GC728X and GC728XP switches, kindly check its data sheet here.
    Furthermore, kindly access the link below to view other NETGEAR Switch models that matches your network requirements:
    NETGEAR Switch Selector
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi tonynsx,
    DaneA
ProSupport for Business
