quaint501's avatar
quaint501
Follower
Dec 25, 2020
Looking for GS108PE v2 power adapter
Hello Communitiy,
I'm looking to replace the power adapter for my Netgear ProSafe GS108PE v2 (POE switch).
  1. I'm not sure what are the exact spec that I should looking for (including plug size)
  2. Where can I buy a replacement? I have found some Amazon listings but unsure if they would work and reliable.    https://www.amazon.com/COOLM-100-240V-Transformer-Interface-Injector/dp/B07GXF8FRC/ref=sr_1_3?dchild=1&keywords=48v+ac%2Fdc+adapter+poe+switch&qid=1608885652&sr=8-3
ProSupport for Business
