4uba
Aug 07, 2017Aspirant
Loop detection and prevention
Hello, Netgear Community. This weekend I have not time to relax and enjoy my beer. Instead I was spent time in Server room with my lovely "roommates" 2x S3300 and 4x GS752TP. I spent few long...
- Aug 07, 2017
Hi,
Sorry about the beer :)
Just turning on RSTP on its own is likely not hepling because the phone does not support spanning tree. That is pretty common that phones don't. When the switch ports (those the phone is connected to) are in "main STP mode" the spanning tree negotiation can't happen as the phone does not understand/support that. Main STP mode should be used between devices that understand and support spanning tree.
Leave RSTP enabled overall and can you then also please try to enable "Egde Mode" on those ports where the phone is connected? Go to: "STP" --> "CST Port Configuration"
Does that prevent the loop now?
Cheers
Hopchen
Aug 08, 2017Prodigy
Hi,
Okay, so if "Auto Edge" is on then that is fine. The switch will detech itself edge devices. Fast link should be OK as well. The VLANs doesn't matter as RSTP does not care about the VLAN config.
However, the issue is likely the same as discussed here:
https://supportforums.cisco.com/discussion/10069336/spanning-tree-loop-through-ip-phone
It is a Cisco thread, but it seems to relate to your issue? It is quite interesting really.
Anywho, I am not sure your switch is capable of BPDU guard as they mention here?
Cheers
- 4ubaAug 08, 2017Aspirant
Hi again,
I would like to summarize my research...
As I previously mentioned, any changes after activation / de-activation Fast Link. Even when I changed it to Auto, in STP - CST Status - Edge Port status changes to True, but anyway storm is performing. So this feature does not help me till now.
But also I found one interesting regularity: when I plug phone`s eth port in switch port (lower port number, e.g. g4), and after I plug phone`s PC port in any higher port number (e.g. g5-g48) storm is not performing. Otherwise, if PC port has lower port number that eth port, storming as in Pirates of the Caribbean!!!
Yalink gives 80-90 Mbps storm.
Fanvil gives 7-8 Mbps storm.
I would like also note results of my research in this case:
1. When I plug eth port, and after plug pc port in lower port number - port up to 7 seconds stays at learning state.
2. After 5-7 seconds port is chaning at Forwarding state, Address tables is removing and storm is beginning (so I mean that ports are in state Forwarding both) - I cannot change it, since I have not BPDU Guard or BPDU filter functionality.
I`m not sure, that even BPDU guard will help me. I will try to find M-series switch to proove it.
It`s not the end.
Igor
Guys,
I found, that in S3300 datasheet marked, that BPDU Guard is present in S3300 and even in GS752TP.
Proof:
Could you please tell my, how to enable this functionality (CLI or GUI does not matter)!!!
Cause I dont have any buttons in config menu. Proof:
Thanks in advance!
Igor
- HopchenAug 08, 2017Prodigy
Hi,
If the datasheet specifies that it has BPDU Guard, then it probably does. I assume it is just enabled and non-configurable (therefore not visible to you). I would not know enough about spanning tree to determine whether the issue of your phones really is down to BPDU Guard or not.
I suggest you reach out to support in this one, to see what they say.
Cheers
