4uba's avatar
4uba
Loop detection and prevention
Hello, Netgear Community.   This weekend I have not time to relax and enjoy my beer. Instead I was spent time in Server room with my lovely "roommates" 2x S3300 and 4x GS752TP.   I spent few long...
  • Hopchen's avatar
    Aug 07, 2017
    Hi,
    Sorry about the beer :)
    Just turning on RSTP on its own is likely not hepling because the phone does not support spanning tree. That is pretty common that phones don't. When the switch ports (those the phone is connected to) are in "main STP mode" the spanning tree negotiation can't happen as the phone does not understand/support that. Main STP mode should be used between devices that understand and support spanning tree.
    Leave RSTP enabled overall and can you then also please try to enable "Egde Mode" on those ports where the phone is connected? Go to: "STP" --> "CST Port Configuration"
    Does that prevent the loop now?
    Cheers
ProSupport for Business
