nickon
Dec 02, 2020Aspirant
Losing DHCP leased IP address after some time
I'm running two NETGEAR switches in my network:
- 1 x NETGEAR JGS524PE (Latest firmware: 2.6.0.48, defaulting to 84.193.203.32)
- 1 x NETGEAR GS108Ev3 (Latest firmware: 2.06.14, defaulting to 192.168.0.239)
They are both configured to receive an IP address via DHCP, which they do initially or after I force them to refresh their IP address. But after some time, they lose their DHCP assigned IP address and revert to the (I assume factory default one) that I listed. These are IP addresses which lie outside the network subnet I am using, so if I want to access them I am unable to.
Both switches are having the same issue. All my other network devices (which are configured the same way and also get their IP address assigned over DHCP) do not exhibit this behavior, only the NETGEAR switches.
Two issues in your post:
Appears the Smart Managed Plus switch models are ignoring the common DHCP standards like a refresh at 50% and renewal on the time given by the DHCP server. Instead, they seem to have a hard coded renewal time of two hours. If the DHCP server isn't available, the devices fall-back to the default IP address 192.168.0.239.
For the "effect" on the JGS524PE ... this is a DHCP assigned IP address. Suspect you have this switch exposed to the wild Internet, and your ISP does DHCP assign a telenet.be public IP address. Almost all Smart Managed Plus tiny management cores (except some XSxxxE variants) can't be limited to a designated management VLAN - so it can happen in such a set-up that the exposed switch will get the public IP address assigned. What can be very bad when your ISP does allow only one public IP address - intended for the router...
- nickonAspirant
schumaku wrote:Appears the Smart Managed Plus switch models are ignoring the common DHCP standards like a refresh at 50% and renewal on the time given by the DHCP server. Instead, they seem to have a hard coded renewal time of two hours. If the DHCP server isn't available, the devices fall-back to the default IP address 192.168.0.239.
That's useful knowledge. I don't know however why (the DHCP service on) my router wouldn't be available though? It's running 24/7, just like my switches.
The only scenario that I can come up with where my router is down and my switches aren't is in case of a power failure and my switches are booting faster than my router. I've just recently renewed the IP addresses on both switches, so I'll try and check on a regular basis (daily) their DHCP assigned IP address and see if they lose it even if there weren't any device reboots / power failures.
Thanks for chiming in.
For the one exposed to the Internet (might be a bad idea in this switch class) I strongly suggest to put up a static IP address, for the ones on the LAN side only, it's just a suggestion.
- Feb 25, 2019Anonymous
