nickon
Dec 02, 2020Aspirant
Losing DHCP leased IP address after some time
I'm running two NETGEAR switches in my network: 1 x NETGEAR JGS524PE (Latest firmware: 2.6.0.48, defaulting to 84.193.203.32) 1 x NETGEAR GS108Ev3 (Latest firmware: 2.06.14, defaulting to 192.168....
nickon
schumaku wrote:Appears the Smart Managed Plus switch models are ignoring the common DHCP standards like a refresh at 50% and renewal on the time given by the DHCP server. Instead, they seem to have a hard coded renewal time of two hours. If the DHCP server isn't available, the devices fall-back to the default IP address 192.168.0.239.
That's useful knowledge. I don't know however why (the DHCP service on) my router wouldn't be available though? It's running 24/7, just like my switches.
The only scenario that I can come up with where my router is down and my switches aren't is in case of a power failure and my switches are booting faster than my router. I've just recently renewed the IP addresses on both switches, so I'll try and check on a regular basis (daily) their DHCP assigned IP address and see if they lose it even if there weren't any device reboots / power failures.
Thanks for chiming in.
schumaku
Dec 02, 2020Guru - Experienced User
For the one exposed to the Internet (might be a bad idea in this switch class) I strongly suggest to put up a static IP address, for the ones on the LAN side only, it's just a suggestion.
- nickonDec 04, 2020Aspirant
You actually make a really good point there about the JGS524PE switch. I didn't notice that the IP address was actually a DHCP assigned (public) IP address handed out by my ISP instead of the factory default one...
What is strange though is that if my switch is in this "public IP address assigned" state and I force a refresh of it's IP address through the ProSafe configuration utility, it is not getting a public IP address assigned from Telenet, but rather a static lease (192.168.1.2) assigned by my Ubiquiti Edgerouter (which is what I intend). It is only after some time that both of the switches get assigned another IP address (either the factory default one -- GS108Ev3 -- or the DHCP assigned public IP address --JGS524PE--).
I'll shortly explain how (and the reason why) my switch is connected directly to my incoming ISP connection. The box provided by my ISP that I use to whatch tv (Telenet Digicorder) needs to get an IP address assigned from my ISP, and therefor should not be behind my home router, otherwise you can't access any interactive content on the box. So in order to achieve that I have a seperate VLAN (id:2) set on my JGS524PE on ports 14, 15 and 16:
- Port 14: Ubiquiti EdgeRouter Lite eth0 (WAN)
- Port 15: Telenet Digicorder
- Port 16: Incoming ISP connection
All other ports are in the default VLAN (id:1) and my Ubiquiti EdgeRouter Lite eth1 (LAN) connects on one of these ports.
- Feb 25, 2019Retired_Member
