hkolind
Jan 22, 2018Aspirant
Low read speeds with ASUS XG-C100C 10gbe connected to Synology via XS716E
I am having trouble getting fast read speeds from our Synology rs3617xs+ using the ASUS XG-C100C 10gbe NIC. I am getting write speeds in the 4-500 MB/s range (which is what the internal SSD is specc...
- Jan 23, 2018
hkolind wrote:The XS716E has to LAGs: ports 13+14 has LAG ID1 and ports 15+16 has LAG ID2 - I can't change anything in the configuration as far as I can see.
Just in case - not mixed the two LAG port sets for the NAS connection by mishap?
hkolind wrote:
The Synology is currently set to "Balance XOR". Other options are "Adaptive Load Balancing", "IEEE 802.3ad Dynamic Link Configuration" and "Active/Standby". I'm hardly a networking pro - so any tips are more than welcome.
Balance-XOR should be fine against the static LAG configured.
To exclude the trunking/LAG from the equation (and taking the fact some other users have reported certain issues), please give a try to- temporarily reconfigure the bond on the NAS to "Active/Standby" and retry,
- temporarily remove the bond config on the NAS, and use just one network link to a switch port (within the same VLAN of course) not configured as a LAG, and retry.
hkolind
Jan 23, 2018Aspirant
schumaku
Jan 23, 2018Guru - Experienced User
hkolind wrote:The Synology is currently set to "Balance XOR". Other options are "Adaptive Load Balancing", "IEEE 802.3ad Dynamic Link Configuration" and "Active/Standby". I'm hardly a networking pro - so any tips are more than welcome.
