WestEndRec
Jan 04, 2023Follower
Making a "Smart" switch "Dumb"
I have a portable audio recording system that uses a Dante network on a Netgear GS310TP Smart Switch. I occasionally need to interface this system to an existing Dante network to get what is essentia...
Retired_Member
Jan 05, 2023
You “Smart” switch actually comes “Dumb” out of the box. It will stay “Dumb” forever unless somebody changes its configuration. That can happen without your knowledge when you leave your equipment unattended. If you want to make sure that your switch is “Dumb,” reset it to the factory defaults. The switch’s documentation should provide instructions on how to do that.
