tonynsx
Sep 02, 2022Luminary
Managed switch on routing mode for dhcp
I have a few CNC machines at work that have RS232 connectors. I know I can get adapters to convert the RS232 to WiFi or Ethernet. I don't want these machines to be on the company network. So ins...
- Sep 04, 2022
A VLAN does not require a dedicated physical network link. Each VLAN does make up a dedicated logical network. So doing this on the XS728 is perfectly fine.
tonynsx
Sep 04, 2022Luminary
Thank you, the reason I want to have these CNC machines connected to a Netgear switch is so I can avoid connecting fiber from firewall (WatchGuard) to switch. Plus, this is another way to keep them away from company network. Yes, I could create a new VLAN for these CNC machines. But this means I need to run cable from firewall to switch.
Is there any Netgear switch that does dhcp and act as router?
schumaku
Sep 04, 2022Guru - Experienced User
- tonynsxSep 06, 2022Luminary
So since I'll be connecting the CNC machines to the WiFi, I don't need the extra ports on the XS728.
Are there any 5 port managed switches that have the same feature as XS728? How about the GS305E?
It has 5 ports, I could use 1 port for connection from firewall if needed, and 1 port for an access point, and I have 3 spares left.
Would be better if there is a 5 port managed PoE switch that does routing and dhcp
