Philipp1991
May 26, 2025Aspirant
Managment-IP & Trunk on the same Port - GS108T
Hey, I'm new to switching with netgear! As stated in the title: is it possible to make the switch accessible via the trunk port while also being in a managment vlan? The setup so far: Defau...
schumaku
May 26, 2025Guru - Experienced User
All GS108T models have - like any Netgear Smart or Managed switches (or for example any "big" managed Cisco switches) - one additional so called CPU port, which can be defined to the default untagged or a tagged network.
It does not matter on how that's VLAN does reach the switch - being over an untagged connection or over a trunk with tagged connection(s).
So the answer on the question is a yes!
