chavez2's avatar
chavez2
Mirroring ports from one switch to another one
Hi! I recently bought 2 Netgear switches to my small company both are GS724TPS that are connected with trunked connection on both sides of the building. The problem is I need to mirror one port from ...
  • DaneA's avatar
    Jun 06, 2017
    Hi chavez2,
    Welcome to the community! :)
    It think its not possible to configure mirror ports from switch A to switch B or vice versa wherein both switches are connected via a trunk connection.  Since the GS724TPS is capable of stacking, I believe it would be best to set the 2 GS724TPS as one stack.  In this way, you can configure Port Mirroring because if 2 or more switches are configured in a stack, it resembles as one switch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
