waldo15
Jun 24, 2023Aspirant
MS108EUP fails to pass/provide DHCP
I have a Multi-gig managed switch (MS108EUP) that is servicing my home network. It is connected to a pfsense appliance and, at the moment, the switch is configured in basic "dumb" or unmanaged mode. ...
waldo15
Jun 25, 2023Aspirant
Yes the switch gets its IP address from the firewall in dynamic DHCP.
I can try the advanced configuration you suggested and report back my findings. Should I set this to only a small number of ports, or all active ports?
schumaku
Jun 25, 2023Guru - Experienced User
Whatever is convenient and can be used to extend testing or experiencing your firewall system.
- waldo15Jun 27, 2023Aspirant
So I ran the test and it also ended up failing. Looking at my Firewall logs there's nothing that I can see that is obvious as to why it failed (if it was a firewall side issue), but I can see the DCHP server was properly setting up addresses and renewing IP leases until the switch just stopped. Once again, a power cycle brought it back online.
Should I start an RMA process with Netgear support?
