waldo15
Jun 24, 2023Aspirant
MS108EUP fails to pass/provide DHCP
I have a Multi-gig managed switch (MS108EUP) that is servicing my home network. It is connected to a pfsense appliance and, at the moment, the switch is configured in basic "dumb" or unmanaged mode. ...
schumaku
Jun 25, 2023Guru - Experienced User
waldo15 wrote:
I can try the advanced configuration you suggested and report back my findings. Should I set this to only a small number of ports, or all active ports?
Whatever is convenient and can be used to extend testing or experiencing your firewall system.
waldo15
Jun 27, 2023Aspirant
So I ran the test and it also ended up failing. Looking at my Firewall logs there's nothing that I can see that is obvious as to why it failed (if it was a firewall side issue), but I can see the DCHP server was properly setting up addresses and renewing IP leases until the switch just stopped. Once again, a power cycle brought it back online.
Should I start an RMA process with Netgear support?
