Boboss
Oct 10, 2019Aspirant
MS510TX - Ports 10Gb in normal mode ?
hi, I want to buy a switch MS510TX. Can uplinks ports be used in normal mode? example: SFP + (10Gb) for 10GB internet input RJ45 (10Gb) to connect the computer thanks
- Oct 11, 2019Yes, of course you can connect PCs, Nas, Webcam or TV etc.
An uplink is a standard Ethernet port that can be used as any other port on the switch, for local devices, or used as an aggregation link (faster speed) to transport other devices' traffic to a core, for instance. I hope this helps
LaurentMa
Oct 11, 2019NETGEAR Expert
Hi Boboss
Sure, you can.
Not sure what you meant as abnormal mode, these two 10G ports, one Copper and one Fiber, only work as standard Ethernet ports. Hope this helps
Sure, you can.
