Boboss
Oct 10, 2019Aspirant
MS510TX - Ports 10Gb in normal mode ?
hi, I want to buy a switch MS510TX. Can uplinks ports be used in normal mode? example: SFP + (10Gb) for 10GB internet input RJ45 (10Gb) to connect the computer thanks
- Oct 11, 2019Yes, of course you can connect PCs, Nas, Webcam or TV etc.
An uplink is a standard Ethernet port that can be used as any other port on the switch, for local devices, or used as an aggregation link (faster speed) to transport other devices' traffic to a core, for instance. I hope this helps
msi
Oct 11, 2019Luminary
Hi Boboss
What exactly do you mean by "normal mode"?
On that switch the hardware install guide for example mentions that the last 2 ports are independent. For comparison: There are switches (I remember several M4100's) where there are 2 physical ports, such a RJ45 and SFP but only one of them can be active at any given time. On that switch both ports should be usable when the other one is.
If you want to connect your internet feed directly to the switch (i.e. you have a SFP Module for FTTH from your porovider) and don't want your router before that you'd have to configure VLANs. I can give more details on that if that applies to your use case.
