Boboss
Oct 10, 2019Aspirant
MS510TX - Ports 10Gb in normal mode ?
hi, I want to buy a switch MS510TX. Can uplinks ports be used in normal mode? example: SFP + (10Gb) for 10GB internet input RJ45 (10Gb) to connect the computer thanks
- Oct 11, 2019Yes, of course you can connect PCs, Nas, Webcam or TV etc.
An uplink is a standard Ethernet port that can be used as any other port on the switch, for local devices, or used as an aggregation link (faster speed) to transport other devices' traffic to a core, for instance. I hope this helps
Boboss
Oct 11, 2019Aspirant
my question is rather:
What is an uplink port?
can I use these 2 "uplink ports" as standard ports to connect any device (computer, NAS, webcam, TV ...) ?
- LaurentMaOct 11, 2019NETGEAR ExpertYes, of course you can connect PCs, Nas, Webcam or TV etc.
