monsieur_cedric
Oct 08, 2021Aspirant
MS510TX, can't manage because "not in the same subnet"
Just received my MS510TX. Using win10 x64, FW is 6.7.0.50 (can't update) so, SWITCH DISCOVERY finds the Switch, but pressing "admin page" gives me a timed-out connection error. SmartControl...
- Oct 08, 2021
One would expect the MS510TX would be able to receive a DHCP assigned IP address, e.g. from your ASUS XT8 Mesh primary node if it's in router mode. Ensure the MS510TX MAC address is added to any security on this router, so it can get access to the network like any other wired or wireless device.
The alternate approach would be to temporarily configure a computer into that other 192.168.0.x/24 network, like 192.168.0.123, MAsk 255.255.255.0, default gateway and DNS 192.168.0.1 (regardless if it exists, and override any kind of connectivity tests. Now you can ping the switch on 192.168.0.239, access the management Web interface using a Web browser, set a fixed IP (not overlapping, ideally outside of the routers DHCP pool) in your LAN subnet (like 192.168.1.123, mask 255.255.255.0, gateway 192.168.1.1, DNS 192.168.1.1). From here ou should be able to reach the switch from your nomal LAN/WLAN network (driven by the Asus router!). Everything under the assumption the Asus does isue 192.168.1.x addresses of course.
schumaku
Oct 11, 2021Guru - Experienced User
monsieur_cedric wrote:
I believe the router did issue an IP by DHCP to the new switch.
Everything works fine, except if I want to manage the switch. Then, I have to configure my PC Ethernet Properties and change the IP to gain access to the switch.
I would expect that DHCP assigned IP config would be set in place on your switch - assuming it's in DHCP mode on the management VLAN.
If this does not work, don't hesitate to get in touch with the Netgear customer service using https://www.netgear.com/support/contact.aspx
