mlaihk's avatar
mlaihk
Follower
Mar 19, 2021
MS510TX SSL import
Will someone please give me a step by step on how to import a CA issued cert into MS510TX?  Before anyone points me to GS728 steps, I have tried it and it does not work on the MS510TX.
When importing SSL MS510TX, the UI is asking for three files:
1)  Certificate
This is quite easy as it is just a plain cert.pem output.
2)  Public Key  (or according to the UI header, an RSA Public Key)
This is annoying as it is supposed to be in the PEM certificate above or can be generated from the private key using openssl as follows:
openssl x509 -in cert.pem -pubkey -out certpub.pem
Extract the Public Key section from the certpub.pem file into pubkey.pem, and then:
openssl rsa -in pubkey.pem -out rsapubkey.pem
3)  RSA ENCRYPTED PRIVATE KEY
This gets me stumped.  I can generate a private key in pem.  I can even convert it into RSA PRIVATE KEY using:
openssl rsa -in key.pem -out rsakey.pem
But there is no reference whatsoever on how to convert that into a RSA ENCRYPTED PRIVATE KEY for use in the MS510TX/MS510TXPP.  And when I paste in RSA PRIVATE KEY, the MS510TX will not take it saying header mismatched or something similar.
Can someone give me a step by step on how to import a CA signed cert into the MS510TX please?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    mlaihk / Don_Thate,
    A community member shared a link here that might help.
    DaneA
    NETGAR Community Team
ProSupport for Business
