tigo13
Aug 28, 2024Star
MS510txm, firmware V1.1.0.7 - anyone with issues?
Has anyone that updated their switch(es) to this new firmware found issues with it? For e.g. any of the following: 1. Upon updating, the switch decided to connect to Netgear Insight - and be on?...
- Aug 28, 2024
I have two MS510TXMs and two MS510TXUPs. I only encountered the first problem on all of them, and I was able to disable Insight on all of them without losing any data. For the one switch that you are having multiple problems with, you might need to open up a case with Netgear.
ShadowMario3
Aug 28, 2024Luminary
- tigo13Aug 28, 2024Star
Thanks for the note - confirming the first. I'll open a case with Netgear regarding the problematic switch then. Cheers,
