tigo13
Aug 28, 2024Star
MS510txm, firmware V1.1.0.7 - anyone with issues?
Has anyone that updated their switch(es) to this new firmware found issues with it? For e.g. any of the following: 1. Upon updating, the switch decided to connect to Netgear Insight - and be on?...
- Aug 28, 2024
I have two MS510TXMs and two MS510TXUPs. I only encountered the first problem on all of them, and I was able to disable Insight on all of them without losing any data. For the one switch that you are having multiple problems with, you might need to open up a case with Netgear.
Josh_Manton
Aug 06, 2025Guide
I had an issue where all my Private VLAN Associations were deleted. It on had the Primary VLAN and the Community VLAN were no longer associated.
