cflatt
Jan 29, 2024Tutor
MS510TXM SFP+ port with SFP Module No Link
Hello, I have a Multi-Gigabit Ethernet Smart Switches (MS510TXM) switch (firmware version 1.0.5.10) with 2 SFP+ ports and I want to connect it (using multimode fiber) to a different SFP port and S...
BrianL
Feb 06, 2024NETGEAR Moderator
Hi cflatt,
Thank trying and for sending the TS file. I find it odd that the SFP+ ports 9/10 are enabled in 10G but did not specify if it will auto-negotiate to other speeds such as 1G. I will check this with our switch Engineering team and keep you posted on updates.
Kind regards,
