cflatt
Jan 29, 2024Tutor
MS510TXM SFP+ port with SFP Module No Link
Hello, I have a Multi-Gigabit Ethernet Smart Switches (MS510TXM) switch (firmware version 1.0.5.10) with 2 SFP+ ports and I want to connect it (using multimode fiber) to a different SFP port and S...
BrianL
Feb 11, 2024NETGEAR Moderator
Hi cflatt,
Great then. Should we look at the (using multimode fiber) different SFP port and SFP module, maybe that's the problem.
Kind regards,
cflatt
Feb 13, 2024Tutor
So currently what I'm trying to connect to is an RJ-5G-SX connector (data sheet here: https://cotsworks.com/wp-content/uploads/2022/03/944-00007-24_RJ-5G-SX.pdf) using those multimode fiber cables. Again when linking through the GS716TP SFP port/module this link works fine. But through the MS510TXM SFP+ port, i see no link on the Switch side however I do see link on the side of the RJ-5G-SX connector. Not sure if there's some compatibility problem I'm not seeing between the two.
