cflatt
Jan 29, 2024Tutor
MS510TXM SFP+ port with SFP Module No Link
Hello, I have a Multi-Gigabit Ethernet Smart Switches (MS510TXM) switch (firmware version 1.0.5.10) with 2 SFP+ ports and I want to connect it (using multimode fiber) to a different SFP port and S...
cflatt
Feb 13, 2024Tutor
So currently what I'm trying to connect to is an RJ-5G-SX connector (data sheet here: https://cotsworks.com/wp-content/uploads/2022/03/944-00007-24_RJ-5G-SX.pdf) using those multimode fiber cables. Again when linking through the GS716TP SFP port/module this link works fine. But through the MS510TXM SFP+ port, i see no link on the Switch side however I do see link on the side of the RJ-5G-SX connector. Not sure if there's some compatibility problem I'm not seeing between the two.
