cflatt
Jan 29, 2024Tutor
MS510TXM SFP+ port with SFP Module No Link
Hello, I have a Multi-Gigabit Ethernet Smart Switches (MS510TXM) switch (firmware version 1.0.5.10) with 2 SFP+ ports and I want to connect it (using multimode fiber) to a different SFP port and S...
cflatt
Feb 11, 2024Tutor
Yes using the AGM731F module I can link up both the MS510TXM and GS716TP switches at a one gig rate based on the amber lights. I can also hook up my external one gig connections through the SFP ports of the GS716TP using the AGM731F module. Still no luck getting external connections to work through the MS510TXM SFP+ ports though.
schumaku
Feb 14, 2024Guru - Experienced User
The original AGM731F SFP Transceiver 1000BASE-SX (Short range, multimode) is supposed to be compatible (and workable) on the MS510TXM SFP+ ports according to the data sheet associated. Of coure, since it's 1000BASE-SX, only a Gigabit Ethernet link can be achieved - as the link LEDs confirm - so this combo should be workable. So,ething for Netgear engineering to look into if it doesn't.
