Squuiid
Feb 15, 2025Luminary
MS510TXPP - critical vulnerability on latest 6.7.0.52 firmware
The Netgear MS510TXPP switch is vulnerable to CVE-2019-16645 on the latest 6.7.0.52 firmware. There has not been a new firmware released for this device since 2022 despite a long list of outstanding ...
BrianL
Feb 17, 2025NETGEAR Moderator
Hi Squuiid,
Thank you for sharing this one. Can you submit /or report it here? Also, opening a support ticket would help to speed up the reporting of the vulnerabilities you found.
Kind regards,
BrianL
Squuiid
Feb 27, 2025Luminary
Thanks BrianL . I submitted a BugCrowd report and it got rejected for formatting, which is frankly not acceptable. I very clearly gave links to PoCs, gave the relevant CVE and the product and firmware affected. The fact that they did not care enough to use this information to address the vulnerability is shocking.
I also opened a ticket, managed to get it escalated to a Level 3 engineer after quite a few emails with someone in Level 1, provided the information asked for, and then nothing. No response for weeks. Not even an acknowledgement.
I have zero confidence in this being addressed and it is very clear to me that Netgear does not value the security of its products. This will absolutely be my last. This is supposedly a business grade switch which is still being sold and 'supported', yet its latest firmware was released in 2022 which carried a published CVE vulnerability from 2019! NOT OK.
