Gazzaspinss
Dec 02, 2020Follower
MS510TXPP End of life?
Howdy! I can't seem to find this model in stock in NZ, I contacted a supplier (pbtech) and asked if they could order it in and was told its end of life and they offered something without 10/5/2.5g a...
Iphie_C
Dec 10, 2020NETGEAR Expert
Hi Gazzaspinss
Thanks for your inquiry. MS510TX and MS510TXPP are not end-of-life.
Meanwhile, there will be two new Smart Managed Pro Multigig/10G switch models with the all-port multigig, non-PoE and PoE, come to the market by early January 2021. They will be good options for the latest NETGEAR WiFi 6 Access Points WAX610/WAX610Y. Please stay tunned for the new switches.
After the launch of the new products that I mentioned above, the current MS510TX and MS510TXPP will still be available to the market.
Iphie
