matslundqvist
Nov 19, 2020Aspirant
MS510TXPP not getting more than 1Gb on 5G End to End
EDIT: Tried posting yesterday, doesn't show up in the board. This is my 2nd attempt. Hi, I have two switches in two locations, CAT6A copper between them in the 10GbE port approx 35m cable lengt...
schumaku
Nov 19, 2020Guru - Experienced User
matslundqvist wrote:Is there a way to "force" lower speed on the port?
This is prohibited by the IEEE standard my friend - autonegoation is mandatory from GbE and up.
Open a ticket with Netgear please.
schumaku
Already considered a firmware update to the current 6.7.0.50 btw.?
- matslundqvistNov 19, 2020Aspirant
I hadn't considered it, but I did the upgrade now. Besides a really annoying "You _must_ change the password from the default" the port status now reflects the negotiated speed in physical status. (you can remove it by using inspect element and deleting it)
My environment is now like this:
server1-----5G-----<SW01>----10G----<SW02>-----5G-----Client
server2----10G/
ifIndex 9 Port Type Normal Port Channel ID Not a LAG member Port Role Designated STP Mode Enabled STP State Forwarding Admin Mode Up LACP Mode Disabled Physical Mode 10000 Mbps Full Physical Status 10000 Mbps Full Link Status Up Link Trap Enabled Octets Received 471682 Packets Received 64 Octets 47632 Packets Received 65-127 Octets 4799 Packets Received 128-255 Octets 4690 Packets Received 256-511 Octets 1319 Packets Received 512-1023 Octets 1810 Packets Received > 1024 Octets 411432 Total Packets Received Without Errors 418710 Unicast Packets Received 416972 Multicast Packets Received 1262 Broadcast Packets Received 476 Total Packets Received with MAC Errors 0 Jabbers Received 0 Fragments Received 0 Undersize Received 0 Alignment Errors 0 Rx FCS Errors 0 Overruns 0 802.3x Pause Frames Received 0 Total Packets Transmitted (Octets) 8359808 Total Packets Transmitted Successfully 52972 Unicast Packets Transmitted 52625 Multicast Packets Transmitted 158 Broadcast Packets Transmitted 189 Total Transmit Errors 0 Tx FCS Errors 0 Tx Oversized 0 Total Transmit Packets Discarded 0 Single Collision Frames 0 Multiple Collision Frames 0 Excessive Collision Frames 0 802.3x Pause Frames Transmitted 0 EAPOL Frames Received 0 EAPOL Frames Transmitted 2
And I'm getting more speed now after the upgrade. Not exactly 10G, but a lot better than before (this is client to server2 (with the mellanox 10G sfp card)). Good call on the upgrade schumaku
Connecting to host 192.168.1.21, port 5201 [ 4] local 192.168.1.127 port 60778 connected to 192.168.1.21 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 535 MBytes 4.49 Gbits/sec [ 4] 1.00-2.00 sec 558 MBytes 4.68 Gbits/sec [ 4] 2.00-3.00 sec 558 MBytes 4.68 Gbits/sec [ 4] 3.00-4.00 sec 557 MBytes 4.67 Gbits/sec [ 4] 4.00-5.00 sec 550 MBytes 4.62 Gbits/sec [ 4] 5.00-6.00 sec 556 MBytes 4.67 Gbits/sec [ 4] 6.00-7.00 sec 557 MBytes 4.67 Gbits/sec [ 4] 7.00-8.00 sec 557 MBytes 4.67 Gbits/sec [ 4] 8.00-9.00 sec 546 MBytes 4.58 Gbits/sec [ 4] 9.00-10.00 sec 556 MBytes 4.66 Gbits/sec
So now we can conclude that the switch interconnect is at least at 5G speeds.
I reran my test to Server from Client, which should be able to give me 5G speeds:
Connecting to host 192.168.1.22, port 5201 [ 4] local 192.168.1.127 port 60882 connected to 192.168.1.22 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 345 MBytes 2.89 Gbits/sec [ 4] 1.00-2.00 sec 332 MBytes 2.79 Gbits/sec [ 4] 2.00-3.00 sec 338 MBytes 2.84 Gbits/sec [ 4] 3.00-4.00 sec 340 MBytes 2.85 Gbits/sec [ 4] 4.00-5.00 sec 340 MBytes 2.86 Gbits/sec [ 4] 5.00-6.00 sec 340 MBytes 2.85 Gbits/sec [ 4] 6.00-7.00 sec 341 MBytes 2.86 Gbits/sec [ 4] 7.00-8.00 sec 340 MBytes 2.85 Gbits/sec [ 4] 8.00-9.00 sec 341 MBytes 2.86 Gbits/sec [ 4] 9.00-10.00 sec 342 MBytes 2.87 Gbits/sec
I thought I might be CPU constrained so I ran a test between server1 and server 2:
Connecting to host 192.168.1.22, port 5201 [ 4] local 192.168.1.21 port 41294 connected to 192.168.1.22 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 492 MBytes 4.12 Gbits/sec 225 380 KBytes [ 4] 1.00-2.00 sec 561 MBytes 4.70 Gbits/sec 962 382 KBytes [ 4] 2.00-3.00 sec 490 MBytes 4.11 Gbits/sec 181 399 KBytes [ 4] 3.00-4.00 sec 547 MBytes 4.59 Gbits/sec 954 376 KBytes [ 4] 4.00-5.00 sec 511 MBytes 4.29 Gbits/sec 468 472 KBytes [ 4] 5.00-6.00 sec 547 MBytes 4.59 Gbits/sec 1005 376 KBytes [ 4] 6.00-7.00 sec 517 MBytes 4.33 Gbits/sec 496 516 KBytes [ 4] 7.00-8.00 sec 478 MBytes 4.01 Gbits/sec 41 477 KBytes [ 4] 8.00-9.00 sec 525 MBytes 4.40 Gbits/sec 658 530 KBytes [ 4] 9.00-10.00 sec 518 MBytes 4.34 Gbits/sec 511 373 KBytes
Locally, using the same switch, I'm getting 4gbit+. Over the interconnect, it's 2,8gbit. What am I missing?
