g_williams
Mar 11, 2022Aspirant
Multicast not forwarded to mrouter port
I have several GS728TPPv1, v2, and GS110TPv2, v3 switches that are part of a network that has a Cisco 9300 Layer 3 switch at its core. The 9300 is also the IGMP Snooping Querier for all vlans. ...
JohnC_V
Mar 24, 2022NETGEAR Employee Retired
Hi g_williams,
Welcome to our community! 🙂
It seems that you are having issues setting up your switch. Please check this article hoping that it would help you configure it with your external multicast router.
John
NETGEAR Community Team
g_williams
Mar 30, 2022Aspirant
Hi John,
Thanks for getting back to me. I reviewed that article and was able to do some more testing today.
The Netgear (728TPv2) does seem to identify the mrouter port. If the encoder and receiver are both on the Netgear, traffic is forwarded to the Cisco (on the mrouter port). The switch also passes mDNS traffic between two ports, and to/from elsewhere on the network - so I don't think "Block unknown multicast" is in play. The v2 switch doesn't even seem to have that option - but the v1 did. On a TP110 I have, "block unknown multicast" would block the mDNS as well.
Anyway - without a receiver connected to the Netgear, the multicast goes nowhere. It does not go towards the Cisco / mrouter port. We are using 239.200.1.20 for our multicast address. I noticed that mDNS was still being transmitted. If i change the encoder to output to a 224.0.0.x address - it gets transmitted (flooded actually) which I believe is correct for that address range.
I guess the main question I have is whether the Netgear is supposed to be sending all multicast traffic towards the mrouter port - or does it only send IGMP join requests/reports and queries? It doesn't seem to be sending all unless something on the switch is also receiving that stream. On an earlier firmware version for this switch, the command "ip igmp snooping unknown-multicast action router-port" would send those packets to the mrouter port without flooding other ports on the switch. I couldn't find an option in the GUI for that - and the command isn't even present in newer versions.
Thanks,
Glyn
