drd2k3
Jan 19, 2021Aspirant
Multicast routing between subnets/VLANs
Hi, Where I work we have purchased a GS108TV3 switch. We are currently trying to set it up so that we can route multicsat traffic between 2 subnets and we are struggling to get this working. ...
schumaku
Jan 19, 2021Guru - Experienced User
There is no Multicast routing on these comparebly simple switches.
As this is a limited environment, you can go the hard way.
Switching -> Multicast -> IGMP Snooping -> IGMP Snooping Configuration ..disable everything.
- IGMP Snooping
- Validate IGMP IP Header
- Block Unknown Multicast Addresses
- Auto-Video Configuration
Switching -> Multicast -> IGMP Snooping -> IGMP Snooping Interface Configuration
- Select at least hte ports where you need the Multicast (port and/or LAGs)
- Disable Admin Mode (for the IGMP Snopping that is)
- drd2k3Jan 20, 2021Aspirant
Ok thanks we'll give it a go and see if we get anywhere.
Regards
Duncan
