Yishay_me's avatar
Yishay_me
Follower
Oct 19, 2021
Route multicast traffic to specific ports
Hi,
I'm trying to route multicast from specific ip addresses to 3 ports.
The multicast traffic is used by a propreitary device that cannot register to multicast groups on my setup and I would like to route the traffic to the ports manually.
Since the only multicast traffic on the switch are the streams I would like to forward, it doesnt matter to me if I route all the multicast traffic on the switch to those ports.
Switch FW is  12.0.13.8.
I attempted to enable the multicast router on the target ports, Switching -> Multicast -> IGMP Snooping -> Multicast Router Configuration and enabled the 3 ports I would like the traffic to be redirected to - (see the attached screenshot) but it did not work.
I should mention that it did work on an older FW version - 12.0.6.7
Any help is appreciated,
Thanks!
Yishay
  • Hi Yishay_me ,
    Running the latest firmware, yes, you're only half-way there with your tentative configuration.
    • Please try the following using the GUI:
    Under Switching/Multicast/IGMP Snooping/Configuration,  please disable "Exclude Mrouter Interface Mode"
    Under Switching/Multicast/IGMP Snooping/IGMP Snooping VLAN Configuration,  please disable "Exclude Mrouter Interface Mode" for the VLAN 1 (if this is the VLAN 1 you are suing on these ports)
    And like you were doing in Switching/Multicast/IGMP Snooping/Multicast Router Configuration,  please enable the ports 4, 6 and 8.
    • Alternatively (same thing) but using the CLI:
    vlan database
    no set igmp exclude-mrouter-intf 1
    vlan routing 1 1
    exit
    configure
    interface 1/0/4
    set igmp mrouter interface
    exit
    interface 1/0/6
    exit
    interface 1/0/8
    exit
    exit
    I hope this will help you!
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi Yishay_me ,
    vlan database
    vlan routing 1 1
    exit
    configure
    interface 1/0/4
    exit
    interface 1/0/6
    exit
    interface 1/0/8
    exit
    exit
ProSupport for Business
