GeneralTortilla's avatar
Nov 11, 2019
R6350 router keeps dropping traffic on specific games
It happens whenever I play games like Left 4 Dead and Super Smash Brothers Ultimate. The connection drops for a second, but relaunching the application fixes it. When playing Left 4 Dead, I can't join public games, else i'll get kicked out in around 5 minutes. I went into the logs of my router, and saw this;
[DoS attack: ACK Scan] from source: 52.94.231.48:443 Monday, November 11,2019 18:42:02
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:39:23
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:38:17
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:37:46
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:37:23
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:37:01
[DoS attack: ACK Scan] from source: 52.94.229.215:443 Monday, November 11,2019 18:36:38
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:35:46
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:35:22
[DoS attack: ACK Scan] from source: 17.57.144.53:5223 Monday, November 11,2019 18:33:50
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:33:21
[DoS attack: ACK Scan] from source: 17.57.144.53:5223 Monday, November 11,2019 18:32:00
[DoS attack: ACK Scan] from source: 52.202.253.199:443 Monday, November 11,2019 18:29:35
[DoS attack: ACK Scan] from source: 52.202.253.199:443 Monday, November 11,2019 18:29:15
How do I fix this? It's been happening for a while and I just want to play l4d, man :(
  • plemans's avatar
    1. What modem are you using? (model number)
    2. What firmware is on your router?
    3. How are you connect to the router? Wireless/wired.   If its wireless, what wireless adapter are you using and what radio are you using (2.4ghz/5ghz)
    4. Are any other games having this issue or just that specific ones?
    5. any other devices having this issue?
    • 1. R6350
      2. Auto updates are on, so the latest one
      3. Wired. I'm also connected wirelessly on my switch, with the same issue. (5ghz)
      4. From what I can see, it's just left 4 dead and Super Smash Brothers Ultimate. Sometimes I get issues with Starcraft 2, but not consistently.
      5. Just my Nintendo Switch and my Windows 10 PC.
  • plemans's avatar
    And what router are  you using?  your title has the r6350 while the signature line on bottom has r6300
