ramram
Feb 08, 2017Aspirant
Need to secure a GS110TP switch
Hi all We just got a GS110TP managed switch. We need it to recognize only a set of network devices and drop the rest. Trying to set MAC filtering but for some reason its not working and all devic...
JohnRo
Feb 08, 2017NETGEAR Employee Retired
Hello ramram,
Welcome to the community!
The best way is configuring MACL ACL, see page 210 of the user manual. It will help you with using the ACL wizard and makes sure that the MAC rules are defined to your specifications. What firmware version are you using by the way?
Thanks,
- ramramFeb 08, 2017Aspirant
It's 5.4.2.22
I still cant manage :((
- JohnRoFeb 09, 2017NETGEAR Employee Retired
Hi ramram,
You can contact out support team so they can walk you through with creating MAC ACL. They should be able to guide you through.
Thanks,
- JohnRoFeb 13, 2017NETGEAR Employee Retired
Hi ramram,
Were you able to talk to support regarding this one?
Thanks,
