ramram
Feb 08, 2017Aspirant
Need to secure a GS110TP switch
Hi all We just got a GS110TP managed switch. We need it to recognize only a set of network devices and drop the rest. Trying to set MAC filtering but for some reason its not working and all devic...
ramram
It's 5.4.2.22
I still cant manage :((
JohnRo
Feb 09, 2017NETGEAR Employee Retired
Hi ramram,
You can contact out support team so they can walk you through with creating MAC ACL. They should be able to guide you through.
Thanks,
- JohnRoFeb 13, 2017NETGEAR Employee Retired
Hi ramram,
Were you able to talk to support regarding this one?
Thanks,
- ramramFeb 13, 2017Aspirant
Yes still lost though...
What I need is this setup:
- I WISH TO BE ABLE TO SET SWITCH TO 'RECOGNIZE' ONLY 2 COMPUTERS BY MAC. THESE 2 COMPUTERS SHOULD WORK ON ALL PORTS.
- IF I CONNECT OTHER PCs THEY SHOUDNT WORK ON ALL PORTS.
Cant get it to work :(
- Carl_zFeb 13, 2017NETGEAR Expert
Hi ramram,
Welcome to the Community!
I think it it possible for you to achieve the goal by mac acl. Try with following steps
1. Go to "ACL>ACL Wizard", select "ACl Based on Source MAC"
2. Add rules
rule 1 Permit source mac **********/00:00:00:00:00:00 (input pc1's mac)
rule 2 Permit source mac **********/00:00:00:00:00:00 (input pc2's mac)
rule 3 Deny Match Every
3. On binging Configuration slect all ports.
You can also refer to the pic
Hope it helps
Carl
Netgear Employee
