sero0815
Dec 05, 2024Aspirant
Netgear GS108E Prosafe Webinterface not responding
Hi, I´m trying to configure this switchtype. I have two of them in front of me, I factory resetted them. I am directly connected with my Lan Adapter to that switch. I can ping it. But when I try ...
sero0815
Dec 17, 2024Aspirant
Hi and thanks for this fast reply.
Actually I found out, that the switches I have, are not supporting Web based GUI. They can only be access by special tools. In this case (GS308E and GS308Ev2) I was not able to discover the switches using NSDT. I needed to use the old ProSafePlus Utility. With that tools I was able to manage the switches. But I never thought that I would need a special tool, with Netgear I was used to use a simple webinterface.
How can I now, which switches support web based access? Because the information provided in the following link are not correct:
The GS308E is listed, but actually not providing access via Web based GUI.
Thanks.
Edit:
Actually I could Upgrade the GS308Ev2 to the latest available version. After that it was at least discoverable with NSDT, but not managable.
RennaD
Dec 18, 2024NETGEAR Moderator
Hi sero0815,
The GS308E does support Web UI. Since you are able to discover it via the old ProSafePlus Utility, I suggest to update it to the latest firmware. There are three firmware images, each supports a different language for the WEB GUI: English, German, and Japanese.
https://kb.netgear.com/000064548/GS308E-Firmware-Version-1-00-11
As for the GS308Ev2, what is its IP address? How about your computer's IP address?
Have a lovely day,
RennaD
Netgear Team
- May 25, 2022Retired_Member
