silvanet's avatar
silvanet
Please help. My Netgear R6400 stopped responding
I can't get the version number but I remember it is a R6400 v2.
I was trying to set up a WiFi AP and I think I set up the subnet mas wrong.
I was trying to set my Netgear router up behind my new AT&T Fiber BGW3200.
When the Netgear rebooted I got the message that the ip address took too long to respond and I can't even sign into Genie. Did I brick it?
  • silvanet wrote:
    I just changed ISP to AT&T BGW320 fiber modem/router. I've been trying to set up so I can use the R6400 to manage my wired and wireless connections, but can't figure out how to do that setup from the AT&T interface.
    That is not possible  if you put the into AP mode, which is what you said in your first message.
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    I can't figure out how to configure the Netgear without an internet connection, and the only connection I can get is on the AT&T.
    Here's what I do:
    • Turn off R6400 from unplug from network
    • Unplug PC from network
    • Turn off PC
    • Plug R6400 into PC.
    • Turn on R6400
    • Aim browser at routerlogin.net or 192.168.1.1
    • Put R6400 into AP mode.
    • Turn off R6400
    Now you can reassemble your network with the PC connected to the modem/router.
    When you plug the R6400 into the router, you will have to track down the IP address that the router has allocated to it. Look for a page with a list of attached devices.
    You could even try doing that now. Find that page in your BGW320. Look for something that could be the  R6400 and aim a browser at it.
    It took me years to get the Netgear configured the way I wanted, especially since I'm no expert on that.
    Only you know how you configured your network and why it took so long, but if you have changed the modem/gateway between you and the Internet, many things will be different. The easiest things to change are the wifi SSID and password. Just read the instructions.
    If you want to use the R6400 as your router – possibly not a good idea with something as old as something from 2015 – then you need to work out how to put your BGW320 into "bridge" (modem only) mode.
    Or just dump the R6400 and use the new BGW320 to run your network.
  • michaelkenward's avatar
    michaelkenward
    Look at the label on the thing.
    You don't need to mess with "subnets" to use the R6400 in AP mode.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    That is for a router that is already on the network. It can be easier to disconnect the R6400 from the network and connect it to a PC that is also connected to  nothing else.
    Reset the R6400 then connect it to the PC and go through those instructions.
    Then you can just connect the R6400 to the main router.
    After that, remember to restart the network.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    Did I brick it?
    Unlikely if all the LEDs behave as expected.
  • plemans's avatar
    did you factory reset it? easy way to get back in.
    • silvanet's avatar
      silvanet
      I tried the factory reset but still can't get back to the netgear Genie user interface. I just changed ISP to AT&T BGW320 fiber modem/router. I've been trying to set up so I can use the R6400 to manage my wired and wireless connections, but can't figure out how to do that setup from the AT&T interface. This is the page, but I don't know what to put in there to allow the R6400 to cascade behind the AT&T BGW. It took me years to get the Netgear configured the way I wanted, especially since I'm no expert on that. Can you please help me?
        michaelkenward
        Here's what I do:
        • Turn off PC
        • Turn on R6400
        • Turn off R6400
