sero0815
Dec 05, 2024Aspirant
Netgear GS108E Prosafe Webinterface not responding
Hi, I´m trying to configure this switchtype. I have two of them in front of me, I factory resetted them. I am directly connected with my Lan Adapter to that switch. I can ping it. But when I try ...
sero0815
Dec 17, 2024Aspirant
Hi and thanks for this fast reply.
Actually I found out, that the switches I have, are not supporting Web based GUI. They can only be access by special tools. In this case (GS308E and GS308Ev2) I was not able to discover the switches using NSDT. I needed to use the old ProSafePlus Utility. With that tools I was able to manage the switches. But I never thought that I would need a special tool, with Netgear I was used to use a simple webinterface.
How can I now, which switches support web based access? Because the information provided in the following link are not correct:
The GS308E is listed, but actually not providing access via Web based GUI.
Thanks.
Edit:
Actually I could Upgrade the GS308Ev2 to the latest available version. After that it was at least discoverable with NSDT, but not managable.
RennaD
Dec 22, 2024NETGEAR Moderator
Hi sero0815,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
- May 25, 2022Retired_Member
