bobsmith12
Oct 10, 2023Aspirant
Netgear GS308E - Help with config
Hello, I need some assistance setting up my GS308E. I want to setup 2 VLANs. 1) I have 10 devices connected to an unmanaged switch which will be connected to the GS308E. This I want to be on VL...
- Jan 24, 2024
Hello bobsmith12,
And welcome to the NETGEAR Community! 🙂
This switch is classified as a Netgear Plus switch. You may try to check the link below on how to configure your GS308E Plus switch.
Have a lovely day,
Rene D
Netgear Team
schumaku
Oct 11, 2023Guru - Experienced User
bobsmith12 wrote:
1) I have 10 devices connected to an unmanaged switch which will be connected to the GS308E. This I want to be on VLAN 10 (or whatever number)
2) I have 1 ethernet that connects to a guest suite's wifi. I want this to be on VLAN 20. This will separate out the guest suite's wifi from our internet.
10 devices-> unmanaged switch -> GS308E -> router
wifi access -> GS308E -> router
Depends if your undefined router is VLAN-capable and can deal with VLANs, or if this router just has dedicated ports for these zones.
Assuming you don't have to care which VLAN ID is used for these two isolated networks, you have two possible options:
Basic Port-Based VLAN
or Advanced Port-Based VLAN
In both examples, I have used the ports 1..6 (like for your primary LAN) and the ports 7...8 (like for your isolated guest network) in dedicated, port-based networks.
Of course, you can take the hassle of a full Advaced 802.1Q based VLAN config:
This is what you want to achieve on a 802.1Q configured network:
Nothing tricky, you just need to define the VLAN 10 and VLAN 20 untagged (access) ports, and don't forget to remove all these from VLAN 1, and finally set the PVID for the access ports accordingly.
bobsmith12
Oct 13, 2023Aspirant
Hello, thank you for the very detailed response!
I have an Asus RT-AX88U router. I can't seem to find anything about it supporting / not supporting VLANs.
So port 1 is ethernet coming in from the Asus Router
Port 6 -> Ethernet to the guest wifi connection
Port 8 -> Ethernet to the unmanaged switch with 10 devices.
Wouldn't port 1 have to be a member of both VLANs?
Are they all untagged?
Sorry, this is so confusing.
