bobsmith12
Oct 10, 2023Aspirant
Netgear GS308E - Help with config
Hello, I need some assistance setting up my GS308E. I want to setup 2 VLANs. 1) I have 10 devices connected to an unmanaged switch which will be connected to the GS308E. This I want to be on VL...
- Jan 24, 2024
Hello bobsmith12,
And welcome to the NETGEAR Community! 🙂
This switch is classified as a Netgear Plus switch. You may try to check the link below on how to configure your GS308E Plus switch.
Have a lovely day,
Rene D
Netgear Team
bobsmith12
Oct 13, 2023Aspirant
Hello, thank you for the very detailed response!
I have an Asus RT-AX88U router. I can't seem to find anything about it supporting / not supporting VLANs.
So port 1 is ethernet coming in from the Asus Router
Port 6 -> Ethernet to the guest wifi connection
Port 8 -> Ethernet to the unmanaged switch with 10 devices.
Wouldn't port 1 have to be a member of both VLANs?
Are they all untagged?
Sorry, this is so confusing.
schumaku
Oct 14, 2023Guru - Experienced User
As your router is not VLAN-aware, there are two port types. One for the normal LAN, one for the Guest WiFi.
In each of my examples, I had the idea for the normal LAN on ports 1..6 (one of these does connect to a router generic LAN port, and the ports 7 and 8 carrying the Guest WLAN, where you connect the Guest-LAN port from the router and the wireless access point.
Unless you have a wireless access point supporting two VLANs with two SSIDs. This would break off the port based config, and you have to go for the 802.1Q advanced one, and configure one port for carrying both networks, where either both would be tagged, or for simplicity have the default LAN untagged (where also the access point configuration would reside), plus one tagged for the Guest VLAN.
