12345_12's avatar
12345_12
Netgear Smart Switch - How do i connect if i don't have a CD ROM
I have a Netgear smart switch. I want to connect to it to look at the settings  but i dont have a CD player and the disk they sent only works with a Windows PC and I have a Mac. How can I connect to the switch and look at the settings ?
  • Hi,
    Head to the GS748Tv5 Downloads, grab the Netgear Switch Discovery Tool for Mac, install and run it. Once discovered, click on the router and a Web browser opens.
    Alternate, you can check your DHCP server (e.g. on the router) for the switch DHCP assigned IPv4 address (e.g. based on the device MAC address - see label), and manually enter it in the web browser URL, like http://192.168.1.23/ .
    Either case, add a reservation to the DHCP server, so the switch does always get the same IP address assigned.
    Typically, CD-ROM contents are obsolete once delieverd - there is always the current firmware, documentation, and more available on the site linked above.
    -Kurt
1 Reply
  • schumaku's avatar
    schumaku
    Hi,
    -Kurt
ProSupport for Business
