adakai
Feb 06, 2022Aspirant
Netgear smart switch VLANS not working
So I just purchased a Netgear Smart Switch. The switch I bought: https://www.netgear.com/support/product/gs108Tv3.aspx I have another dumb switch that it is connected to with a crossover cable. I...
schumaku
Feb 08, 2022Guru - Experienced User
Of course the VLANs work as expected: Each VLAN does make a dedicated network, leaving tiny details like STP and RSTP alone, each behaves like a unmanaged switch for each network.
You need to look into the IPv4 routing, being on an additional fully fledged router, or limited to some extent on the switch itself.
- adakaiFeb 08, 2022Aspirant
so not sure if you read my post entirely, but I posted a video that I followed exactly so never did touch STP and RSTP.
What do you mean exactly by IP4 routing? Like is there a specific setting I should be looking for?
- schumakuFeb 09, 2022Guru - Experienced User
Show us the switch IP config and the VLAN Routing config.
Does your Proxmox network config require a trunk port, so tagged?
Also add the exact switch model and hardware version and the firmware in place.
Shuddering a little bit reading about an unmanaged switch involved here - for what should be dedicated networks and dedicated IP subnetworks.
