adakai
Feb 06, 2022Aspirant
Netgear smart switch VLANS not working
So I just purchased a Netgear Smart Switch. The switch I bought: https://www.netgear.com/support/product/gs108Tv3.aspx I have another dumb switch that it is connected to with a crossover cable. I...
schumaku
Feb 08, 2022Guru - Experienced User
Of course the VLANs work as expected: Each VLAN does make a dedicated network, leaving tiny details like STP and RSTP alone, each behaves like a unmanaged switch for each network.
You need to look into the IPv4 routing, being on an additional fully fledged router, or limited to some extent on the switch itself.
adakai
Feb 08, 2022Aspirant
so not sure if you read my post entirely, but I posted a video that I followed exactly so never did touch STP and RSTP.
