adakai
Feb 06, 2022Aspirant
Netgear smart switch VLANS not working
So I just purchased a Netgear Smart Switch. The switch I bought: https://www.netgear.com/support/product/gs108Tv3.aspx I have another dumb switch that it is connected to with a crossover cable. I...
adakai
Feb 08, 2022Aspirant
What do you mean exactly by IP4 routing? Like is there a specific setting I should be looking for?
schumaku
Feb 09, 2022Guru - Experienced User
Show us the switch IP config and the VLAN Routing config.
Does your Proxmox network config require a trunk port, so tagged?
Also add the exact switch model and hardware version and the firmware in place.
Shuddering a little bit reading about an unmanaged switch involved here - for what should be dedicated networks and dedicated IP subnetworks.
