RumorConsumer
Aug 04, 2019Tutor
Netgear switch disappears from Meraki
I have a GS310TP that is connected directly to my Meraki MX65 SD-WAN device. It was showing up in the client list on the Meraki dashboard as having claimed an IP, I was able to log in, all that jazz. ...
- Aug 06, 2019
Adding an NTP server to the config does it!
schumaku
Aug 05, 2019Guru - Experienced User
The thing with many "attached devices" UI design requires that a device does talk through a device/router/security appliance. Ethernet switch management interfaces sparsely talk to the Internet (very different from most computers or mobile devices), some "active" polling by ping, SNMP, or a simple LLDP-MD would be able to confirm the switch management interface is still active.
We see the very similar question on Netgear's consumer routers - switches seem to disappear from the Attached Device lists very easily.
Using a static IP makes it even harder, as there won't be any BOOTP/DHCP process.
RumorConsumer
Aug 06, 2019Tutor
- schumakuAug 06, 2019Guru - Experienced User
RumorConsumer wrote:Adding an NTP server to the config does it!
Cool idea - this is causing the IP traffic will help the Meraki to recognize it as a system present and active on the network.
