Ru123
Jan 08, 2025Aspirant
Disappearing SSID nighthawk be9300
I’m hoping someone here can help; every time I power cycle my router the SSID completely disappears and I can’t find it on any of our devices. Before turning off and on again everything is fine and connected to the internet etc. talked to customer support and they suggested factory reset. It’s updated to the latest firmware and I have factory reset multiple times, which fixes the issue, but as soon as I turn it off and on again the same problem occurs. (Reason for power cycling was trying to fix son’s Xbox connection, and subsequently have been retrying mostly out of disbelief). I have power cycled using the physical button, unplugging fully for a minute, and also rebooting using the app. I don’t have a computer with an Ethernet port if this is relevant. I am so disappointed with this experience and hoping this is fixable.
After looking through the community some more I think this might be what’s happening; my isp requires vlan group tagging. I also tested and it doesn’t happen until i change that setting.
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537Hi Ru123, Thanks for the info. I've sent you a PM with the link for the tiral firmware that fixes this issue.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Which RS model do you have? RS###
How is the wireless configured on the router.
Might pick up a USB to ethernet adapter if you have a computer that doesn't have ethernet port to access the routers web page.
I'd keep in contact with NG support and update them on continuing problems. Ask about an RMA.
- Ru123AspirantFirmware is V1.0.1.60
We have fttp so the router is plugged in to the nbn box with a cat6 cable.
Its RS300
What is an RMA?
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537- BH_CNETGEAR Expert
- Ru123AspirantI have tried both ways, and they disappear either way. The default also disappears, there’s no way to find or reconnect at all without factory reset.
